02 cavaliet
Guest S and S
Guest FastBackJack
1/4s are easy. Take out package tray, makes it real easy (comes out quick) Matrix sucks! If you dont have a way of doing matrix well, then paint or vinyl will work.
All in all, pretty easy. :lol
Guest FastBackJack
No not at all. Fold the back seat down. Pull out the 2 tabs there. Pull off the 2 side panels that the tabs came out of. Pull off the 3 child seat hook bezels. Pull out tray. Take out speakers. Take out light. :lol
Unless you cut out around the light. Then you probably dont need to take it out. But most of the time it IS pretty tight on the bottom.
Cavaliers and sunfires for some reason are the most popular car I tint...literally hundreds of them..yeah , sand down the dots..I use 1000 sandpaper on a dolly..black vynal works well ..when pulling out the 2 side peices there are 3 plastic clips per side ..be careful not to break the bottom ones. door panels pull back nice..some have metal clip(s) you have to pull up with the panel..easier instalation if you heat a few fingers for the doors and over -cut a bit on each side of the doors ...some have a lot of play :thumb
