Glue method on BG
HI all,
I have been reading and searching the forum about gluing the back glass. Well, today I got my first chance to try the glue method. Man, was it a PITA........what did I do wrong???? I used Eileen's glue from Wal-Mart, but I also have the Elmer's glue. Could it been the glue or the method below?????? This is what I did:
I squeegee as usually for a back glass install.
After that, I lift back the film to the dot matrix and apply glue lengthwise along the film and dot matrix.
Put film back in place, wrap a hardcard in a cloth and started to squeegee the excess glue out (with pressure).
Now, I thought it looked really good but as I got outside to take a look, the dot matrix area looked milky and whitish.
What to do.....any suggestions as to why it changes color like that....
The car is a '95 Nissan Sentra...easy install, just this problem....tempurature was low 70's.
Thanks for the help. :DD
  • Replies 28
1) Eileen's glue
2) with pressure
[*]334210
use the blue elmers school glue
or drill down the TOTW threads for Exact-Oh's clear glue/oral syringe method
not to much pressure or you will have the same air trapped around the bubbles
as if you used no glue
I will dig out my matrix pix for 'ya :DD
1) Eileen's glue
2) with pressure
[*]334210
[*]334214
Thanks Zolar.....any pics would be great...Also, the first time I squeegee it wasn't alot of pressure so the film just fingered up so I hit it w/more pressure, then it looked like there's not even glue there...
here is an example of ugly dots on a Mustang (not my work :DD ) no glue
here is one of my Mustang installs with blue school gel
here is a cavalier with the glue too
with the glue you can see through the dots
with the vinyl you get tunnel vision :lol
:DD:DD:lol2
Zolar,
That's how mine looked like in the first pic after  I was finish with the glue.....what happend? So, I should try the Elmer's blue glue and light pressure...
how much glue u apply?
[*]334228
I think too much pressure, you don't want to push all of the glue out
it will be lumpy untill it dries, but it will dry crystal clear :DD
I just run a line of it across the film, where the dots meet the glass
and push lightly with a hard card in a blue shop towel (scott blue paper towels)
I push up only a few inches at the time, working from side to side, gradually working up the dots
Zolar,
[*]334228
[*]334230
Thanks Zolar...... :DD
    3. 5
    4. 4
    5. 5
    6. 5
    7. 0
    8. 0
    9. 5
    10. 5
