Old Cars
If you decide to remove the glass, there is also another option. They make a black glass primer that comes with a sponge applicator attached to the end of it, kinda like a shoe polish applicator. You can apply a black border around the perimater of the window and make it look like all of the new vehicles. All you have to do is tape off the edges of the glass to the width you want. It should permanently bond, so if you have problems with the "gila "later on, you can remove the film and reinstall on a black border with no light gaps. We started doing this here on a few custom hot rods, and now its all we do because everyone likes the new look, and as was said, butyl tape is cheap, and if you are restoring this car, it may be a good idea to remove the chrome and check for any rust, clean and prime to prevent it from spreading. Hope this helps.
Just thought I should give this a shot at tip of the week. :finger:
This post has been promoted to an article
A local glass guy brought his 69 olds in for tint and it had this primer border on it you speak of :finger:
it made the rear window a breeze. good tip!
I remember many moons ago someone mentioned this for applying around gas struts on vette back glass and other annoying back glass
Which is the best place to get this stuff with the applicator?
How long is the realistic lifespan of it?
Do it go on the inside or outside of the glass?
Auto glass shop should have the primer,dont know how long it lasts, but I know it goes on the inside and if you get it on any interior surface get ready to fork out the big bucks to replace stuff. :finger:
We buy ours from our auto glass supplier, PPG. The stuff is called Betaprime Urethane Primers, 5500 sa 1-Step Glass/Frit Primer. It is made by Dow Automotive. You could try CR lawrence for a similar product, or Somaca. There are most likely several companies out there.
It should be a permanent bond, but tint is suppose to last a lifetime as well. :finger:
We have a few old hot rods around, and one that has been done about three years ago, and still looks great.
You could also use this stuff for those dot matrix problems, it dries, after being applied to the inside of the glass, almost the same color as the factory matrix. I haven't done this, yet, because the glue right now works great when I need it.
crlaurence
crlaurence
I think Tintdetective uses this stuff for dot matrix! :finger: Just dont get it on you!!!!
It should be a permanent bond, but tint is suppose to last a lifetime as well. :bingo
crlaurence
I think Tintdetective uses this stuff for dot matrix! :lol2 Just dont get it on you!!!!
It works great for frit lines and matrix's, I have found some other uses as well.
I get mine from Crlaurence also...
Good tip; making the border that way.. :lol2
excellent tip. :lol2 I've used this primer several times (since I share a building with a glass shop). just don't get it on anything except the window. :bingo the nice thing too is that the foam tip can be cut to any size and angle. :lol2
it can also be used to fix cut or damaged frit borders. it's a perfect match IMO....
      Auto window tint claims/performance question
    2. 3
      Help me pick?!
    3. 6
    4. 10,092
      The Off Topic Thread
      How -tough- is the scratch coat
    6. 1
      What is the best value plotter to cut PPF and window tints?
    7. 0
      Help me pick window tint!
    8. 3
      Help me pick?!
    9. 3
      Help me pick?!
