Anyone use JWF NS-25 frequently for commercial applications? Its described as having a "Reverse hybrid construction -- aluminum metallized layer with a charcoal dyed film (dual reflective)". Will this stuff fade or turn purple over time? Seems like it would since it is also a non sputtered film. If it will, how long do you think it would take to turn facing south (ohio)? Looking for some serious insight on this guys. Climber?
Guest haroldshouseoftint
I haven't used the Night Scape, but I have used all of their other flat glass films, they held up OK here in AZ
I do have some MG05 on my house, and I am quite suprised with that, it still has its original color (I compared it to a piece I saved off the roll that was in a closet, no sun exp) :spit
Guest vclimber
If the UV absorbers are in the adhesive layer only and it has dyed layer then it is only a matter of time before it goes.
My guess would be yes based on what I have seen happen to J around here... maybe they fixed it though? :beer
I've installed a little bit of it, and it's super cool looking film, but it was only about a year or so ago, not enough time for long-term results.
I did have a glass breakage claim on a dual pane window, so be carefull, but Johnson has been easy to work with and the film installs very nicely. I like Johnson's Dry Adhesive. :thumb
    2. 6
    4. 6
    5. 4
    6. 5
    7. 6
    8. 0
    9. 0
    10. 5
