2008 WRX
Underground
Well.. so much for the lovely frameless glass. Plus they added a useless quarter glass on the back C pillar as well. Its easy to get to though.
The rear deck is all plastic like the Toyota Carolla and Mazda 3 but is tight to the glass and comes up a bit. It makes removing the AWD decal on the inside of the rear glass a royal pain in the arse.
The door panels are held on by 4 screws. 1 by the door handle, one in the door pocket/switch plate, and once you pry that up, there are 2 more right there. Theres a lil spot towards the front of the switch plate with a notch to put something in to pry it up. Be careful prying up the door switches/pocket though. Its a silver painted plastic that looks like it can scratch easily if youre not careful.
All in all.. not a bad car to tint. Pretty basic honestly. The door glass is flat as can be and the rear glass is an easy shrink. And no thick defroster lines to worry about. :dunno
Ill post up pics shortly. :thumb
We've only got the hatchback model downunder till sometime next year when we see the sedan.
The front door glass has terrible for and aft slop movement which makes fitting tint a bugger as the glass can vary its position as it goes up or down.
Same thing with the rear doors.
The hatch can be done in one but fingers from the sides.
Devil
    3. 8
    4. 8
    5. 2
    6. 8
    7. 8
    8. 8
    9. 2
    10. 8
