Dodge Avenger/ Dodge side seals
mustangdroptop96
  • Replies 27
Guest automediapro
We just tried a 2011 Avenger tonight and it was a NIGHTMARE. The seals are soooooo tight and run down the window into the door kinda as part of the track. We have done other Avengers that were older with no problem. .
So, are you saying the 2011 .. you have removed the seals both top and bottom with no problems?
Guest l1ld3v1lrydr
Wow, you guy's are making me feel good! I've only been seriously tinting for about 2 years solid. Already have an 08, and a 2011 Avenger under my belt. Not gunna lie, they both were pretty hard because of the tightness of the sides, But I got them both done with out pulling anything on either and had no problems on the outcome!
Deff not my favoritest car to do... But I don't know that I would say the worst!
Guest Kokomo Tint & Dent
I pull panels loose, remove bottom strip, tape sides, and pass a wedge or a stiff hard card in the side channels to pry them open a bit. It definitely helps. Full liner peel and slide tint in. Takes a while but looks a heck of a lot better than tucking.
    2. 3
    4. 3
    6. 4
    8. 4
    9. 4
    10. 4
