Black out film
  • Replies 29
Guest Sprinter
global for black out here easy to work with, it will scratch so sand your tools down for a smooth finish. easy to do for the drop method I use a shortend broom handle.
Guest tintslut
most black rubber gaskets can be removed safely on the sides and the bottom.
Check a corner of the bottom gasket first, before removal. Make sure they can
be replaced easily, by pressing into the mullion.
SOME GASKETS are glazed from the outside , before the glass is set. These are
usually 1/8 to 1/4 inch in thickness , they are easily identified. Dont try removal.
If in doubt, ask someone at a glass company to show you the different types of gaskets, or thumb thru a Somaca or CR lawrence catalogue.
