2000 VW Passat estate
s&cautostyle
tailgate trim comes off easy enough, same as most audi/vw, 2 screws and a good sharp pull, you just need a few more weetabix!!!!
Sometimes te split like the Mk4 golfs... nasty, I leave them in, but flush the buggers out...
Door pannels I leve on an pull the rubber out... easy motors!!!
Hi guys,
I did the Passat this week managed to strip the door cards, them covers on the door handles are tight !! I took the rubber seal with the felt on it out to minimise contamination it came out mint which is good !!
Cheers for the advice once again !!
