T4 caravelle sliders
pulsar2000
Guest naughtydog
You cant remove the catch, I have tried it with the windows out of the van.
You can use an opaquer pen - or a bit of vinyl on the outside.
when you say out the van ? as in the frame still ?
I guessed this may be the case, some Vw forums sugest removable,
any way guess I will go tight & get the felt tip out, Thanks nick :spit
Phone Paul at Auto Asylum Maidenhead Berkshire 01628 782 782 ,He does the local VW Commercial Dealer and has always removed these .
Including my own vehicle,they are tricky due to spring Mech inside but I know it is possible and looks better when the border around catch is finished properly.
Good Luck
You are far enough away for him not to mind ,I hope :spit
Guest naughtydog
I had a look with the window out and couldnt work out how to get it apart, maybe it was in place - I cant remember. It does look fiddly either way.
The ones I do know are all aftermarket sliders that you can remove the catch with a couple of screws.
