2011 Malibu's
southcentraltinting
Alright, Here is the low down. There are retainer pins on the outside of the panels, remove this and you can pull back and snatch the seal out, and then remove the seal around the window to stare at the whole piece of glass. The front windows are laminated so, watch the heat. :boogie The quarter windows back matrix on all sides except the side up against the rear window as is with most cars. Lots of room on the small windows for excess film. The rear glass is almost flat, the deck however does come up about 1.5" above the bottom matrix, this can be solved with a bulldozer. There is some foam along the bottom of the glass, I just pushed it down a little with the bull dozer so I could let the film slip down there. The rear roll down windows have a huge rolling bevel on the top, like it was grinded down and arced to much, watch your trim along the top, it can walk away from you if your not paying enough attention.
    3. 8
    4. 8
    5. 2
    6. 8
    7. 8
    8. 8
    9. 2
    10. 8
