2008 Camry
finishlineautosports
Easiest way to do a camry 1/4 is to drop the bottom back corner in first. Feed it down below the gasket until the top edge is below the rubber then pull it up into position. comes out very clean if done right. As for the doors, the top edge of the door will un-snap from the gasket and then the gasket can easily be removed. Just remove the 1 screw behind the door handle pull and thats it. Pop the top edge of the panel back, remove gasket easy peasy super clean.
    2. 1
    4. 2
    5. 1
    6. 8
    7. 8
    8. 2
    9. 8
