back glass help;57 chevey post
Guest andygarcia
whats the easiest way to shrink the backglass,dry,b-powder,wet,.and when i install it it grows alot.
Probably best to tint it out of the car. I've done one or two, they were out of the car and no real issues. In the car, GFL.
Generally, (depending how the film is reacting on the glass) i'll clean glass really good, then wet glass and lay film, go on and cut film all the way around windows gasket to get my pattern then ill slide top down maybe 2 inches and shrink top out, then do the same on the bottom and pray she lays when you install :D i would imagine you could also dry shrink with a lift and pull leaving extra film top and bottom to pull on then trim and final wet check if needed..These type glass make you feel like you've done something if you get a nice clean install on it with it in the vehicle :hmmm
    3. 8
    4. 8
    5. 2
    6. 8
    7. 8
    8. 8
    9. 2
    10. 8
