DIY Film Handler/Dispenser
I got tired of having all of my film boxes stacked at the end of my table and having to swap the box I need from the bottom of the stack to the top. Then having to pull my film across my table which is narrower than my film.
So I decided to build a dispenser. It holds 4 rolls of film. I built it so that even the lowest roll will let out 60in of film, more than enough to do a back glass. It holds my 50% not that anyone wants 50% on a back glass
I used 1in PVC for the rods and to hold the rods I used closet rod holders from Lowes (pic of of package below)
I had all the wood so my total cost was under $10
There are a few improvements that I want to make like adding straight edges to make straight cuts and a couple other things I have in mind.
post-33201-0-84925600-1335983504_thumb.j
post-33201-0-00421700-1335983504_thumb.j
post-33201-0-64010200-1335983591_thumb.j
That looks good, you could get the same result by making it more steep to save space.
Here are mine:
Thanks. I like yours. It looks cool with all of them lined up. You have a ton of film.
I wanted to keep my wall space clear. I may put some shallow shelving on the wall below it to hold things.
My bottom line of film is about 5ft off the ground.
You did a good Job on yours.
Here are mine:
Dang! Way to steal his thunder! LOL!!
Great idea. I need to make a vinyl rack. I keep knocking them over and damaging the vinyl. I just havent had time to make one. Y'alls design looks easy and cheap. Maybe I'll do the same.
Guest T4Tint
Very creative idea.
I found myself using the bottom self alot lately, my upper dispenser are now storage of other things :)
    rewiredtech.io
    Tint My Ride
      Graphtec Plotter
    4. 2
    5. 2
    6. 1
    7. 4,178
      What did you tint today?
    8. 1
    9. 4
