Best/Lowest Watt Heat GUn?
I own and use a 1500w heat gun from harbor freight that does the job, but anybody every used a lower wattage heat gun? have any recommendations?
I was run it off of a power inverter, so the less watt the longer it'll last. Here's one I found at radioshack, but I don't know if it will shrink enough film at one time:
http://www.radioshac...AA&gclsrc=ds.ds
Any help would be much appreciated
that gun will never work. sadly i know from experience. back in early 2000's i was doing trucks in high school. and after finding a hair dryer doesnt work. i did try this. i dont know why i ever thought it would work.
most heat guns are around the same wattage. if you give up wattage you may sacrifice fan power or overall heat.
wagner from home cheapo or lowes. is a minimum. i tried a similar gun from ace hardware. thing would shut off randomly. and take forever to heat up.
Guest Tint Activists
Wow, kinda small.
It might work but it looks like it will be a more concentrated area that gets the heat.
Maybe for small stuff but I wouldn't try to shrink a Beetle with it. :thumb2
exposing a very concentrated area to heat will crumble the tint.
