Corny tank question...
Any tire store should have them. Ask for a threaded metal valve for a semi. They are rated at 100 psi.
shouldn't they be rated higher?? i've seen most of the posts on here say they run them about 80-100psi? i thought you went up to 145psi? going that high for window tinting seemed a bit much but hey, what do i know right??
80 to 100 psi is plenty. And the semi valve will work fine. That's what I have on both my tanks.
only thing i am still an issue with is how to connect the hose to the ball connector?? i feel skeptical about using a hose clamp and would rather have a pressure fitting for it, any ideas on that?? I did a search and found some posts, but they are old and the pictures have been taken down
Its ok if the stem doesn't hold the pressure...as long as you aren't standing over the tank when it decides to pop off...it'd make a mess of your swing set, ouch!
BTW, kegoutlet.com has everything you need.
You have to have a popit to connect the hose to the tank. Serach for a liquid side popit for soda kegs.
do they make them with a quick disconnect for like a regular air hose fitting?
    Tint My Ride
    2. 3
    4. 8
    5. 14
      South facing windows DR film
    6. 0
      The History of Window Tinting
    7. 0
    8. 0
    9. 3
    10. 8
