Bomb drop\drop hang
  • Replies 24
Guest bbvaldezjuly4th
Getting there bud! I will post a couple here for ya! I call it bottom feeding or bottom loading. Very good prep! :-)
I will post a rear as well due to the added difficulty:-)
yeah checked it this morning. I counted 5 pieces of felt in it. Ironically that was where it hung up a little. I think if you get a smooth drop with no snags it would be fine.
Nicely done there.  :cool
That's exactly how I do the bottom in first, learned that method entering installation in 1980. Learned the top on first method as a film sales rep in 1996. Once both are polished in technique you will begin to alternate between them and recognize when one will suit a particular car better than the other.
To avoid top edge snags, wait a tad longer to flip the top or in other words take the bottom half of the pattern down a little more. You can gauge it by slowly moving one top corner to the glass to check your distance from the glass edge. Re-wet where needed. Also, just before going to the board for your pattern give the top edge area another spray. Gravity will muck you up, sir.
    2. 3
    4. 3
    6. 4
    8. 4
    9. 4
    10. 4
