Will a Glue puller pull this
Little delay here, but a glue pull kit without the ability to tap with hammer and tap down will probably just donut that up.  Cause a high ring around the center.
The heatgun and duster ninja trick can work on some dents, but not many.
On 4/18/2016 at 2:48 PM, Rjsi said:
Take your heat gun, heat the area really hot, then take a can of compressed air and blast it, it will pop!!!
Its' not gonna work on those dents.  Too much pressure held down by the curve of the sheet metal there.  You MAY get them smaller but you will also recrystallize the metal into the dent shape by basically heat treating it with the repeated heat/cool cycles making it harder for a real tech to repair.  Leave it to a pro....
