Help wet shrinking side windows
1 minute ago, jh812 said:
 This is the factory edge of the film. You'll want to shrink with this. If you shrink the opposite direction it'll distort the film.
sorry im still a bit confused so i now understand what the factory edge is, so how would i go about shrinking in that direction, i thought ou only shrink up and down, sorry if i sound a bit stupid
  • Replies 33
ok i now understand what you are talkin about and that is the way in which i am trying to shrink however fingers keep popping up agen, should i squeegee out all the water from the tint before shrinking?
Just now, jh812 said:
 I'd do a rough cut just a little bigger than needed in case you burn it.
alright thanks ill try tomorrow i fink i might have not shrinked with factory edge so ill try tomorro thanks for the reply mate, and how much experience do you think i will need before i can start tinting peoples cars?
I agree with JH. Talk to Stan and see if you can get his DVDs. Since you're across the pond taking his course in person is probably not a doable option - but the DVDs would give you the basics.
    4. 2
    5. 2
    6. 2
    8. 0
    9. 6
    10. 4
