Help with mini cooper front widows
On Mini Coopers where the window rolls down just a little bit when you open the door what is the trick?? when I lay the film and squeegee it out everything is great. but soon as I close the door it rolls up the rest of the way and I got figures at the bottoms that I cant get out.. what do you guys do on these type of cars? remove door panels? thanks
I trick them then leave them up for a while longer after tinting them as they dry and I finish the car. Sometimes I barely shut the doors and carefully move the car and set it in the sun or elsewhere in the shop. Remember to untrick them, pull the door latch, to release the latch to close doors when finished. Sometimes the latch may stick and just use a screw driver to gently guide the latch and pull door handle at same time to get it to receiving location.
