2015 Acadia door panel
You're always better off pulling the panel on that one, which is a little different between the driver and passenger sides. The driver side has a screw behind the handle and then two screws behind a cover plate under the pull. The passenger side has the same screw behind the handle but the other two screws are in the pull itself, the face of it pops out to give access. All are a T30 torx if memory serves me correctly and you need a pretty long one to get the ones in the pull in the passenger side.
You’re correct they were all T30 and the panels couldn’t have been easier to pull! Turned out great. I won’t always have to do it, but I think I’m gonna have to break down and start pulling panels a little more often it made it way to easy.
Edited by TQtinting
    2. 6
    3. 3
    6. 3
    7. 6
    8. 3
    9. 6
    10. 4
