Tempered glass only around here. Plate glass if effing dangerous.
You might be able to find an old sliding glass door for free somewhere. I find a few every year getting tossed out.
I like to keep a board a little wider than the film roll. My main glass that I cut patterns from is 45x78 (sliding glass door minus the frame).  I like to mount the main board vertical. Glass on the other side can be whatever fits your space.
I used to use a rolling frame but it's a pain to keep moving around. Always worried about it falling or breaking while moving it.
1 hour ago, PAP said:
How big should I go?Does 30 x68 work?
Yes. I've worked off of smaller or sometimes no glass at all in some mobile situations.
Get it cleaned up with some soap/water, razor blades and #3 steel wool. Drill a few holes in the frame and attach it to the wall you plan to work from. Be sure to use a heavy lag bolt and pre drill a hole into a stud in the wall so it doesn't fall and hurt someone or the vehicle you're working on.
    d2iwindowfilm.com
      Independent Contractors needed for Security Film Project- Houston
    5. 4
      Mutoh Plotter
      Reveal Molding/Belt Moldings
    8. 4
