8
Applying PPF profitable?
8
High speed material feed
Update to this.... We were using a Graphtec FC7000-100 plotter and the Digi Cut software and the machine wouldn't work correctly. We contacted Digi and they did a live modification on our software which solved the issue. Strange thing, the plotter would still never cut through the pattern consistently. (parts would cut totally through and parts would not cut even through the film) We switched to Core and instantly everything cut 100% consistent and without need for software modification. Perhaps if we had a newer plotter than the FC7000 perhaps the Digi would work as expected ??? Dunno
