2003 toyota matrix
FRANK
I havent done one yet but from the picture it looks like a pos, wiper motor int he way on the inside, struts probably in the way, also it looks kinda curvy on the sides. good luck.
Guest tintslut
pry off the strut clip with a small screwdriver, and support the glass when tinting.
Cut the wiper motor close and hard card it in .
Guest thetintshop
be sure and shrink down a little further than the bottom of the frit. cause the top of the glass disappears under the wing. you have to cut it a little short on top and a little longer on bottom, so you can slide it up a little when you lay it inside. if you don't, picky customers will find a light gap when looking at it from certain directions. DON'T cut the holes until you have it inside. the back glass is a complete b***h, but the rest of the car is typical toyota, easy money.
and I recommend removing the wiper motor, just makes it a little easier.
    2. 4
    5. 5
    6. 5
    7. 5
    8. 4
    9. 5
    10. 5
