Old bug...I'm in need of help
Guest naughtydog
  • Replies 27
Guest Tint Wiz
what method di he use...I was going to say to try and wet shrink it or dry but do 1/2 then lift it  and re lay it and do the other 1/2 ...ive wet shrunk them before...before I dry shrank..
[*]281783
Hi Tintman
I did the window with powder dry and used metal film first then used Suntek carbon second time round, that got it down and the glass was out on the table to shrink it :popcorn
Guest solarspot
Most are just a standard rubber gasket not to bad to get in and out. If you pull the back out than the sides will be easy :thumb Or you could get lucky and have the ones that pop open and vent just unscrew them.
I have a 69 and the back glass is on the shelf. I thought about tinting it one day and pulled it off the shelf and VERY quickly put it back up :thumb:thumb GOOD LUCK
