Chrysler Neon
Guest naughtydog
Guest naughtydog
Today I tinted a chrysler neon, they may be known under another name in the US?
The doors were easy, the rubbers tucked easily so no problems there, but the back glass...what a pain.
I tried it first in a hp film with a powder shrink, I got it down eventually but struggled with the bottom corners, I kept getting little creases there!!
The top of the glass has what I can best describe as a striped area of ceramic lines, not a matrix, I mounted the film and it just flippped off, it would not stick to this area??
In the end I treated it with dot devil solution and wire wooled it, I then shrank a piece of standard dyed suntek film and this went ok, it was a lot easier to shrink the HP film. I still had a couple of little fingers that popped up but I got it down in the end.
I dont like trashing film but seem to struggle with the more difficult windows in HP - any tips anyone?
Ta
Naughty
  • Replies 24
I find it works out alright tinting it too..I just have a personal problem with heatshrinking film heavily on a matrix/black lines area.
If you choose this way, make sure you blade/sand and use something a little tackier than your film slip ( alcohol mixture/ dirt off/ elmers glue ) pick your method...everyone's got a favorite :dunno
Guest naughtydog
The neon may be a dodge...but over here...it is a Chrysler!!
Do you find the backglass easy to do? if so, it must be me being a :dunno
Guest naughtydog
this one was a biatch...I am normally OK at shrinking but this sucker...well. it sucked!!
I tried the soapshrink as well and I was getting creases, the hp film seems to need a lot of heat to make it move?
Naughty
    2. 4
    3. 4
    4. 4
    6. 4
    8. 1
    9. 3
