child safety
Guest shrinkmasterb
Guest shrinkmasterb
Worked on a GTI the other day and all windows went fine until the last one---the passenger door. upon raising the window with top micro edged, the window went all the way up and then immediately back down. You are unable to stop the window no matter what -pass switch, driver switch, nothing works. The car has a safety system on that door that senses resistance and immediately rolls the window all the way down. After redoing it 3 times finally figured out that you must apply upward pressure to outside of window while raising it to overcome the added resistance of the film drag. Good luck.
hahah yeah that has got me a couple times, you really have to watch it if you pull the weather stripping out from around the top and side of the window, the glass can get loose and roll up and hit the top and the sensor rolls the window back down :thumb your tint goes on the floor or down into the door pael all crunched up :ford
    3. 5
    4. 4
    5. 5
    6. 5
    7. 0
    8. 0
    9. 5
    10. 5
