Huper Optik vs. V-Cool
Guest Litespeeds
Guest Litespeeds
Just talked to a V-Cool rep and tried their film in 70%. They claim 55% heat rejection and 94% Infra-Red rejection from this almost clear film. I tried it on my front doors and it is actually very good. Not sure if it really reduces that much heat but I would say at least 45%. Will have to use a BTU meter to get accurate readings.
I haven't tried the Huper Optik film yet but I have heard it is very similar to V-Cool.
Has anyone used both films and tested them? What are your thoughts?
Guest Rama
V-kool does reduce alot of heat, their figures are accurate from my experience. Haven't used it in a long time. TS uses Huper, I am sure he can answer your question on the differences.
Guest metint
I heard of huper adhesive failure in arizona, anyone else?
vkool likes to use infrared reduction which can be very misleading. infrared if I remember from the iwfa test is only 53% of total solar to begin with.
55% total solar energy reduction doesn't mean it's all heat?
Huper Optik Sech looks very similar to VK-70. Same technology but a little darker.
VK-70, 70% VLT, 55% TSR, 90% infrared
Sech, 58% VLT, 54% TSR, 82% infrared
Same adhesive system
If you take VK-70 and compare it to Elite Slate 30, you will have less BTU's from VK-70. Sold VK-70 just by doing the BTU meter.
Guest tintslut
Luv the HUPER!!! Sech and Drei are comprised of noble metals, Stark is inert ceramic coating ( titanium nitrate to be specific) . How many premium
window films can be installed on auto and flat? Panorama? NO!
Vista? NO ! Sunscape? UH-NO! Take a BTU meter with me on sales calls,
helps to close the deal. NON - reflective appearance with high heat rejection, what could be better.
Arizona Is a big state, are we talking adhesive failure in Flagstaff or
Somewhere in Maricopa County? In all the time I tinted in phoenix, I wish
I could say I never had some film go bad,,, but I did have some redo's
REGARDLESS OF WHO MADE THE FILM. EVEN in a good film market ,
everyone in the Valley seemed to just want tint, gimme that dyed stuff.
Its cheap, and when it goes bad, I will get it replaced.
Look in the Back of the New TImes, you can still see tints advertised
for 69$ and up. 8)
