Tint On Tint
Guest andrew59usa
Guest andrew59usa
I just had my new car tinted, and they messed up. Now they want to put tint over tint. Is this an acceptable procedure?
Thanks,
Andy
andrewsmith1@comcast.net
  • Replies 28
Guest andrew59usa
You are correct, they put on a lighter shade then I ordered so they want to put on another layer. So what I was looking for is that this is not an accpeted pratice to put tint on tint (Cover Up) to make it darker. Thanks :please
Guest REITZ20
Will it work? probably, but I would think the adhesive between the tints may not last as long as it would on glass.
Would a professional tinter do it? Absolutely not.
If the tinter did not properly convey the darkeness you were looking for; his/her fault. Tinters mistake, tinter needs to redo it. Correctly.
However if you came back 2 weeks later and told them you want to change it, it would be at tinters discretion. :please
