Who really makes 35% as an istaller at a tint shop?
The direction of shrink
Welcome to the forum! I would recommend Global non-cap ppf and get a second bottle with plain water only to flush the edges for better adhesion. If you're leaving water behind try using a different squeegee. I prefer a dark yellow turbo from Interwest. Instead of heating I think you should be streaching the film into place to pull the fingers out.
