08 Malibu
Guest willie
Easy car, seals pull around doors
Rear brake light is embedded in the deck but can easily gotten behind
may take the place of the easiest 4 door car on the market to tint besides the G6
:thumb
  • Replies 25
Guest darkdan
Bottom gaskets come out easy too.
Front doors I just removed that top push rivet on the side of the panel.
Rear doors I took out both rivets and a 10mm bolt behind the door handle (cover just pulls right off if you pull on the back side). To get the rear panel back into place I had to loosen the rest of the push fashioners to wiggle it back into place.
Yup, gaskets around the side come out just like an Ion. Nice!
If I can do this car in 2.5 hours it shouldn't take anyone else more than 45 minutes.
Guest clint4883
do yall pull the whole surrounding seal out with the lower gasket? thats what I did on the last one. made it a lot easier, and looks better than trying to cut it short and stick as much as you can be hind. this why you cant see where the tint ends. its real easy and only takes a few extra seconds. makes for a better product in the end imo.
