Jetta
Guest datdude
Actaually those quarters aren't that hard. Cut a HAIR bigger on the curved side, and even on the bottom and front leading edge. If Your cuts are true, and not all Ziggy You should be golden. :rollin
:rollin Ill take my easy reach sometimes and run it under the curved side as well. It helps to give you a lil more room to work the film under the gasket.
