Window Won't Roll Up
Smack the motor with a hammer while pressing the up switch and see if it's just jared. Sometime's it can be as simple as a bad tooth in the regulator. I've seen moter's go back to working for quite awhile after a jam. While other's need to be replace and wont budge.
If that doesn't work make sure you are seeing 12 vlots alternating between the 2 motors wires up controling the switch up and down. It is possible you burned out your switch, but doughtful. :thumb
run some wires from the battery to the motor, if it goes up the motor is fine, if not, bad motor. You can gently tap the casing of the motor while holding the up button, something the brushes stick to the armature from corrosion.
    rewiredtech.io
    Tint My Ride
      Graphtec Plotter
    4. 2
    5. 2
    6. 1
    7. 4,178
      What did you tint today?
    8. 1
    9. 4
