LOTP #164
  • Replies 1.8k
Actually, I just got back inside, and don't check suspension parts with pry bar putting tension on the part.
I popped the upper ball joint off the steering knuckle, and it does not have any loose play.
I also popped the outer tie rod off the knuckle, and the outer and inner do not have any looseness, that would leave the lower ball joint, and I do not have the 24mm socket to remove the retaining nut.
I have tried all 4 tires on the left front, and it is BAD shaking, and all 4 tires are good, had that checked first.
It has been gradually getting worse, tomorrow I will go by and have the guys at the shop check lower ball joint, seems to be the same type of shaking my t-bird had when the uppper ball was ready to go.
Good news, they will only charge $30 labor, and the part is only $20.
Tire balance could be it, gonna toss on the spare in the morning and see how it does, still going to get the suspension checked just to be on the safe side, and get the tire checked as well.............
Hopefully somethin that simple...............
Will let ya know when I find out tomorrow ! :thumb
