Chevrolet Cruze
Guest Bkrebs1
what kind of tape you guys using that doesnt fall off the seal when it gets wet??
on cruzes I pull the rubbers and gaskets out, tint sides, shrink and install rear, then.re install gasleta and.rubbers.... I prob have 15 20 min total in messing with the.rubber.and.gaskets..
I use the cheapest duct tape I can find. It seems like the cheaper it is, the stickier it is.
You can also run your heat gun around the felt a couple times before you tape it. It can help the tape to stick.
