2013 equinox
bamh5
I pulled the panels on on the front, one 7mm behind the handle, and two 8mm just below the handle. For the rear I removed the 7mm behind the handle, but I pulled the top back and grabbed the seal out. To put the rear back on I flexed the top of the panel. The rear should really be removed to get the sweep, but I could not figure out where to get to the screws holding the panel on. The rest of the car was simple.
I tinted one of these and both of the small rear port windows had contamination in the same exact spot... so I stripped them and retinted, razored and.scrubbed.... same result...... then repeated to get same result again...i told the customer it could be because of the suction.cup from the factory that it.had.done this..... it had me irritated beyond belief..
anyone dealt with this??
Got to razor blade everything welding slag or whatever it is happens more often than one would think. At the dealer I would just have service order a new glass cause you can't get it off. And even if you could it leaves a pitted surface.
yeah I think it will work... I know I cut it out of my 24" roll & not my 40" roll... there was definatley some to spare but not sure how much...
just take a 10mm socket to.pull the wiper blade off and.your good to go!
freakin equinox.pisses me off!! has to be the smallest window too!
      70% Expel Plus on windshield ripple fix
      WANTED: EXPERIENCED FLAT GLASS WINDOW TINTER IN NEW JERSEY
      help arquitectural in Puerto Rico heat
    4. 3
      Stratos 70 on windshield, what is this?
      Sales and Customer Service Advisor- Part time $18/hour
    7. 8
    8. 14
      South facing windows DR film
    9. 0
      The History of Window Tinting
    10. 0
      Seeking residential/commercial window tint installer in Las Vegas, NV
