I need some Help from the master!
I got a customer dropped off windows from old classic car. qy9e2uje.jpgzyjydy2a.jpg
Dirty gets pushed up from Bottom part of the windows . I cleaned it many many times too. I've been always had problems with those old windows. Its my weak spot. And I just can't figure it out.
I know spray less water helps .
How do you tint those windows?
Thank you for your help !
Do your shrinking and snap shrink if you want, if it even needs it, when you install just make sure the tint doesnt touch the bottom channel, ie leave a small gap and it will be perfectly clean.
:trustme do 'em all the time but usually in the frame.
Well you could have dry scraped the channel out with a razor blade and then sealed it off with a clear fast drying sealant, that would be one way if you are unable too get a clean install with the situation like you are experiencing .
This combined with minimal water.
Thanks guys! I pressure washed window first and used minimum water and shrink the bottoms and It worked !!! :))) next time Im gonna have to charge extra for those windows. I'll post the pic later. ! Thanks again!!
    Tint My Ride
      Flat Glass Installer NEEDED
      Now hiring experienced window tinter
      Any XPEL Dealers?
    4. 13
      Where can I order Window film online?
    5. 1
      TintX Puremax and Koolmax
    6. 7
      Question about VLT variance
    7. 7
    8. 7
