I' take sliced with an OLFA any day over this
thanks for the input, going to try the nt blades -
Bump on this. I spoke with Film & Vinyl Design and the rep told me their cutting software contains the drivers for the Graphtec 4100 models. They also mentioned it will work with Windows 11. Any one have experience with this program, good or bad things to say about it?
