2014 passatt
Their not that bad. You can undo screws behind cover plates to take trim off but I just pull back and use a hook tool to pull the rubber out. Theirs a few different types, even a frameless so maybe you'll get lucky but either way their not bad at all
The only thing I do differently on the new ones is pull the front two panels back (makes it way easier to tuck behind bottom seals, and trim the back window small so the inner a pillars don't interfere during installation. I've done a few 12 volt installs on the new ones, and the clips for panels are a lot stronger than the old ones, so be careful if you pull any.
