small bubbles
Most likely dust specs. Clean all around the window not just the glass. Roll down the window ,and clean any dirt out of a all the seals with a hard card and towel. Try to be in  an environment that is clean, and does not have any moving air.
I had this problem when I first started too. Aside from a clean working environment, make sure contamination isnt in your solution as well. I run water through a coffee filter each time I fill my tank and I no longer get the little white specs
what spray systems is everyone using? I have a metal canister with a strainer in the spray handle. some times I still get little silver/whits spots may be 5 per window. I usually use a popsicle stick and it rubs out after baking in the sun for 15-20min. it does not look like dust I could be wrong......
