How is the rear on 2008 BMW 335i hardtop vert
TintOhio
Any tips on the 2008 335i hardtop convertable?  How is the access to the rear glass also do you need to take the top down to tint the side windows, tight gaskets?  Honestly I have never tinted a hardtop vert.  Thanks in advance!
I take a little more time on these just to make them easier.   I do the back glass first and then focus on the side windows with the top down.  You can do either on first, but either way you will have to let the doors and 1/4's cure well before putting the top down or up (it drops the windows automatically when you operate the top!!! remember this part​). The gasket aren't as bad as you think once you have the top down.  Nothing will mess up the back glass when you put the top down, so you are safe there.  Take your time and work out a pattern that suits you best.  These are not that hard if you can do a BMW coupe or 4 door.  Good Luck.   :thumb
