409 or ammonia
Actually let me correct myself here. I actually only use amonia when doing the trash bag technique. After pulling off the film on the rear and sides I use an actual WINDOW TINT Glue Remover & Glass Cleaner made by PRO Detailing products. This stuff works great! Spray on, let sit for a few seconds and it really starts to loosen that glue up
I've used invisible glass for a long time now. Lightly coat it, let it sit. A quick scrub with a white pad, another coat, sit, scrub, then a final heavy coat, sit little longer and the last scrub you'll have most of the left over glue to one side. After I scrub I "squeegee" if you will, with the scrub pad to one side, that way left over glue isn't floating around so much, then a yellow turbo or something and it'll be good
    4. 2
    5. 2
    6. 2
    8. 0
    9. 6
    10. 4
