Guest bbvaldezjuly4th Posted November 28, 2017 Report Share Posted November 28, 2017 58 minutes ago, Tint Slayer said: How much Dawn you have in that bottle? 5 squirts Link to comment Share on other sites More sharing options...
Guest bbvaldezjuly4th Posted November 28, 2017 Report Share Posted November 28, 2017 Just now, bbvaldezjuly4th said: 5 squirts Link to comment Share on other sites More sharing options...
Tint Slayer Posted November 28, 2017 Report Share Posted November 28, 2017 2 hours ago, bbvaldezjuly4th said: FYI - I measured one pump out of a few bottles like that and they're all around 2 mls per pump. So you're at around 10 mls with 5 squirts if it follows that 2 mls rule, i use the same amount. I've been flip flopping between Dawn and Joy (both not concentrated). They're both made by P&G, i wonder how similar their ingredients are, though Dawn is hands down the more slippery of the 2. Link to comment Share on other sites More sharing options...
quality tintz Posted December 3, 2017 Author Report Share Posted December 3, 2017 On 11/28/2017 at 4:10 PM, Tint Slayer said: FYI - I measured one pump out of a few bottles like that and they're all around 2 mls per pump. So you're at around 10 mls with 5 squirts if it follows that 2 mls rule, i use the same amount. I've been flip flopping between Dawn and Joy (both not concentrated). They're both made by P&G, i wonder how similar their ingredients are, though Dawn is hands down the more slippery of the 2. Oh no wait till they harp on you for using dawn hahahaha Link to comment Share on other sites More sharing options...
Stampe Posted December 11, 2017 Report Share Posted December 11, 2017 5 squirts How mutch water is it in those bottles? Thanks for great tips! quality tintz 1 Link to comment Share on other sites More sharing options...
quality tintz Posted March 9, 2018 Author Report Share Posted March 9, 2018 On 11/28/2017 at 12:14 PM, Tint Slayer said: How much Dawn you have in that bottle? Yes how much dawn in bottle do video please??? Link to comment Share on other sites More sharing options...
Super Dave Posted March 9, 2018 Report Share Posted March 9, 2018 Another thing to keep in mind is water quality around the country is very different. It will impact the amount of slip you need to add. Especially if you use tap water , added a specific filter, or you buy bottled water for install. Also, I use several different lines of window tint every day, which means I adjust the amount of slip accordingly. When one of those factors change you will have to do some trial and error to get the slip back where you prefer it. quality tintz and Tint Slayer 2 Link to comment Share on other sites More sharing options...
Tintmaster08 Posted March 9, 2018 Report Share Posted March 9, 2018 When I top load I remove the whole liner and place it on top of the door panel with the side that was touching the adhesive facing up. I found doing it this way cuts down on creases and contamination. Creases can be easily heated out using the heat gun in a waving motion over the area your trying to fix while usin your thumb to feel how hot it gets before over heating the adhesive. When your thumb heats up to the point where you want to pull it off the glass is a good measuring method for when it’s hot enough to push the crease out without distorting the glue. I’ll make a video tomorrow to demonstrate what I’m talking about Tint Slayer 1 Link to comment Share on other sites More sharing options...
drtint Posted March 10, 2018 Report Share Posted March 10, 2018 On 11/19/2017 at 6:02 PM, quality tintz said: Wondering how long it took all the top loaders to learn new bottom load technique? About as long as it takes to waste your time taking the door apart. Cheers Link to comment Share on other sites More sharing options...
highplains Posted March 10, 2018 Report Share Posted March 10, 2018 jh812 and Super Dave 2 Link to comment Share on other sites More sharing options...
