"1979 lincoln town car"
This window is one where the bottom gets shrunk first, then the entire sheet is lifted and re-positioned with the top edge of the film below the vinyl's edge.
Reset the horizontal anchor working remaining shrinkable excess to the top and go.
The bottom (already shrunk) should be carefully smoothed out to ensure anything needing to be heat formed ends up on the upper half; all the while avoiding what overlaps the bottom framework.
It's trick but easy enough not to cause too many headaches at install.
Oh and ah, run some painters tape along the vinyl's edge that meets the glass to shield it from the heat. Two layers might be best. Tape it off as though you are going to paint.
I've used and shown folks this method on newer cars that have top edge tucked well under an air spoiler.
