2003 crown victoria
Mdog
you can pull back the top of the door panel and take the seal out, it seperate from the door panel now, it used to be attached to the door panel, you could pull those back on the older models also but the new ones are much easier, lots more room to feed your tint down if you peel the whole thing like I do on those cars.
so just grab the top and pull up and remove the whole seal.
