Honda civic coupe
Guest Tint Wiz
  • Replies 38
Guest skeeter
We've done 3 of the 03 's recently. The first 2 we're done by my co workers, and they said they we're a pain in the ass to remove seats,side panels etc.. I did my first Saturday - and they we're right - and from now on the price goes up if we go that route. The binder thing works ok, but cleaning behind is hit and miss. Also, I always seem to leave small moisture pockets which sometimes dry leaving tiny air bubbles with the binder method. If I were only getting $110 I'd cut around also. :)
Guest Al-tint
Newbie, sorry for the old topic post.
We take out the rear deck. Easier to tint and we think it looks better.
First deck removal was an hour, now 7 minutes.
Seats
- 10mm socket
- remove two bolts small seat back, remove.
- remove one side bolt on big back, remove big seat back.
- remove one bolt seat bottom, right of centre, pry up two clips on seat front, remove.
Side walls
- Phillips screw located behind wall handle, remove one per side.
- PULL wall from car, no problem.
Pillar caps
- Use pry bar on plastic push clips.
Deck
- Remove bulb from deck in trunk
- slide belts from slots on deck
- prybar UP the front of the deck 4 clips.
- PULL deck forward and remove.
- prybar the 4 clips at the base of the glass and put back in the deck
Speakers
- cover or remove.
Replace all in reverse. No problem. :shock
We do this for a new Honda dealership weekly.
Guest tintgod
I dont have to remove the bake seats on these..just the side pillers and that is it..its to hard to explain how I do it..next time I get one in ..I will take pics...it only take me about 3 min to take it out.. :evileye
I dont have to remove the bake seats on these..just the side pillers and that is it..its to hard to explain how I do it..nest time I get one in ..I will take pics...it only take me about 3 min to take it out.. :evileye
I'm with you TG. I don't think I have ever pulled the back seat out. Although you do have to be careful getting it out not to scratch or crack. Saves alot of time though :evileye
Guest made in the shade
ok,I got the ideal tool for tough to get to spots(rear brake lights,on honda civic coupes)....get a bbq burger flipper,dip the end in that rubberized paint you can buy at your hardware store,and ta-daaa!.....I tell ya ,I could market these things and make a fortune!
    2. 2
    4. 8
    5. 8
    6. 2
    7. 8
    8. 8
    9. 8
