Need some Help
Guest FIREMAN68
Guest FIREMAN68
I have a customer that want me to tint a 3ft by 4ft window at a hospital. He told me that he wants this window to be as dark as possible and dose not want to see threw it. So my question is if I was to put limo on this window and its still isn't dark enough for this guy can I put another layer of limo over the first one? If yes how long should I let the first layer dry before I put on the second. And if this was you how much would you charge for a job like this. Im thinking I should charge alot for this job due to this guy only wanting me to do one window.
Thanks to those who respond. :gasp
Guest FIREMAN68
Does the window get sun exposure-is it insulated-tempered? You need to know these things! :gasp ss
[*]331405
no sun.
he said that it was going to be a lab room
[*]331402
Firemang
If it is an interior window blackout film wont allow you to see anything
opaque white (frost) may also obscure vision enough for privacy, and allow a full spectrum of light
if it is an exterior window that gets direct sunlight
.....no darker than 20% ..........unless it is reflective
or the seals , and/or glass could be broken
from the glass absorbing the solar energy, instead of reflecting it
I personally would avoid laminating layers of film
but I have done it in the past without incident with
20% Stainless Steel over 35% Solar Bronze
here's some of that blackout
if you cant get a sample...I could get you a 3'x4' piece of blackout for this job
so you won't need to order a partial roll
I might even have some opaque white
PM me if you need it :gasp
if you put a non black out film or white opaque,
say you put 5% limo or 20%.
if the lights are "on" and the people from the exterior of the lab are looking in, they can, because of the light inside the room or the brightness...
What did you end up using??
I know it's after the fact, but I would agree with trying to see if the white frost would do the job. I've done a number of jobs in medical buildings with white frost. This one we did on both sides.. Very hard to see anything from either side, but let light thru.
But on the flip side, I've also done blackout where they need total darkness..
RoAcH
