NEW F-150
Guest tintslut
Guest tintslut
Ahmm the new F-150, 5 windows in a std cab pickup truck
the rear side windows roll down....No felt ,, but a thick ass rubber gasket,
to get in the way,,,, THANKS FORD!
  • Replies 22
I have been preparing the salesmen here for when a person calls with a 04 f150 regular cam taht is has 5 windows and to price it like a extended cab, well see how mane fuckups they do before they get it right.
For those of you who need to know.....these door panels are a major PITA to remove. I remove the panels from 97-03 with just a couple screws. But these TURDS are rediculous. 2 8mm behind the release handle, 2 6mm on the bottom of the door, 1 10mm under pw/pl housing, remove speaker cover, 4 5.5mm in speaker, remove plastic clips that the 5.5mm screws went in, lift panel off. I WILL NOT be removing these stupid panels.
