Paint protection film
Guest sa tinter
Guest sa tinter
paint protection papa slanga here  :lol  alcohol solution prep and computer cut patterns from bekaert for me.    :shock    white and black paint are the 2 worst colors for PPF installs IMO.  but still do 'em all the time.    :lol
[*]357053
Blade - can you be a bit more specific on the alcohol solution thing. :bingo
Is this something I can buy from a pharmacy/Dr*g store?
And when should I apply this ? When the edges are showing dirt ? :DD
Guest sa tinter
Thanx a lot - will surely use this advice. Also heard that a white painted auto is quite difficult to
keep clean on the edges.
[*]357041
any light color car will show dirt arround the corner, just tell them to use rubbing alchoal, and a q-tip on the edges :bingo
[*]357045
Stipes - Please can you tell me what a q tip is. Im from way south and tend to be a bit slow-
so please help me on this one. :shock
Guest sa tinter
[*]357041
[*]357045
so please help me on this one. :coffee
[*]357324
its one of those stick thingys that have cotton balls on both ends and you stick them in your ears to clean out all the goop.
Blade - can you be a bit more specific on the alcohol solution thing. :coffee
And when should I apply this ? When the edges are showing dirt ? :spit
[*]357322
most alcohol solutions are water and rubbing alcohol mixed anywhere from 75% water to 50\50 mix :lol2
not sure what blade uses, but over here I use 50/50 in the cold. and a 4 second drizzle of soap in another bottle for slip.
