Hands a wreck
Guest Braud Spectrum
Guest Rama
My hands crack and bleed too, but not as bad as some of you it seems. I notice if I don't drink enough water, my hands will crack worse. You might try upping your water intake and see if it makes a little difference. Also, some good aloe gel can help. I use an aloe gel, that is mostly aloe, and also has some comfrey in it. Its relatively clear, you don't want the lotion stuff, it doesn't have as much aloe in it. The gel soaks in fairly quick.
  • Replies 33
