1-Peec Beetle
Guest MidcoastMW
Guest MidcoastMW
As a few of those on the board already know...Ive been wanting to get my hands on a New Beetle to shrink that back glass. Well my popz does custom auto-body and on occasion collision work. Well, He had a Beetle in so I cut a nice big peice of HP-20, grabbed a dryer-sheet and heat gun and went out there. :tantrum
The film rolled out just as I had imagined it would, and did not look to bad. :gasp
I set my horizontal in the middle and went at it. Everything went smooth until the last 4" on top, and the last 4" on bottom!! :lol2:beer
It was finger after finger after finger!!!!! None the less I burned a lil spot and creased a lil spot.
:beer Whats the trick to this??? :tantrum
I MAY go back this weekend if I have time to try again with a method Ive used on trickier back glass and has worked.
Put the horizontal anchor waaaay up top. JUST under the matrix, so this way the top will be reasonable to shrink, and then for the bottom you will have all that space in the center to suck up all the slack. I think that'l do it. Any tips/suggestions???
:beer:)
Guest MidcoastMW
stretch that bad boy....top and bottom.....pull the hell out of the film.....
You mean pull the outside corners out more??? That sounds like a really good idea. Cuz the problem I had was obviosly TOO much bunched up on there to shrink! :beer
Can you explain a 'lilmore' on the details... :beer of the stretching.
If you pull the film it should stretch when you apply heat. Work from the middle of the window out to the edge on the finger(s). Some will stretch the middle and then the sides, but I have found that the middle will lay down when the sides are stetched out. FTI has the stetching tech on their most recent how to video. They show using "tabs" on the top corners and pulling. I have learned to do it with the whole top a bit more.....
With the Bug you have room to pull the bottom also as long as it doesn't have any spoiler wing. I did one bug windshield by stretching and shrinking.....it was out of the vehicle and I had a hard time because I was pulling so hard and I had no one else there to hold window...it was an improvise as it was sold by a shop for me and I really didn't want to do it...but the shop is one of my better customers....so I got it done.
When you start with the stretch you will begin to see the film change shape. I will look a bit odd compared to simply shrinking, but you will see it make the change and learn what works.
Hope this helps.
Good luck...
Guest tintman AZ
One thing that kind of helped me is when you get near the rough area where it felt like it wouldn't shrink anymore, I lift the film off the glass, top and bottom, lay it back down. For me it seems to allow the area you just shrunk to shrink some more. And sometimes do it a couple of times.
Guest JerzeeTint
I did a VW dealer for years.
I cut it pretty big, shrink it as normal, then when I get to the last few inches, shrink what I can then I pull the whole thing up and re-shrink it and pull and re shrink.. I've tried allot for this car and this is the only thing that works for me... :beer
Don't flame me but I swear I can wet shrink a bug rear window in less that 15 minutes.
Spray the window down roll out the film (40in. roll) so you have about three to four inches of overhang on either side.
Anchor the film down the center from left to right.
At this point you will use the lift and pull technique that I explained years ago even before that guy showed up a Rico's :lol2
There should be for or five fingers along the top evenly distributed. Tug on the center finger while lifting it up off the glass about 2-3 inches. This should blend the three fingers together to create one large one. Heat the large finger back and forth until you get to the top of the glass. The film will just lay down and if done correctly the film won't even get hot so you don't take a chance on ghosting.
If you have any questions PM me and I will give you my number and explain it better over the phone.
:quote
At this point you will use the lift and pull technique that I explained years ago even before that guy showed up a Rico's :quote
:lol2
This method is plastered on the front page
Its not to hard to find it has a big red box that says NEW on it :wall
